Старый 17.04.2013, 14:23   #26
mdsn
Аватар для mdsn
Автомобиль: e36 sedan 320i AT [m50b20vanos] '93
mdsn Нейтральная репутация
Сообщение от Hopp Посмотреть сообщение
d72.6
на е36 72.5 вроде
mdsn вне форума   Ответить с цитированием
Старый 17.04.2013, 14:24   #27
Вес репутации: 158
t1msk8, точно не скажу, может и встанут.
Старый 17.04.2013, 20:05   #28
r4bb1t
Аватар для r4bb1t
Автомобиль: томатно-овощной компот 15-ти летней выдержки
r4bb1t Нейтральная репутация
Ребята, вот ссылочка по подборке дисков на основные модели bmw. Надеюсь понимаете по английски.
сцылко
Или так,чтобы с размерами ЦО:
All ET/OFFSET is still dependent on tyre and wheel size so bear this in mind if you are trying to fit wheels from one model to a different model, also if the car is lowered then you may have issues with rubbing/non fitment due to fouling.
The higher the ET number the more the wheel will sit inside the wheel arch
1 Series E81/82/87/88 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 35-45
3 Series E21 = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread. ET 12-20
3 Series E30 = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread. ET 15-35
3 Series E30 M3 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 27-30
3 Series E36 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-47
3 Series E36 M3 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 35-47
3 Series E46 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-47
3 Series E46 M3 = PCD 5x120 centre bore 72.5mm and M12x1.5 bolt thread. Fronts ET 30-47, Rears ET 20-27,
3 Series E90/91/92/93 = PCD 5x120, Centre bore 72.5mm and M12x1.5 bolt thread. ET 30-45
3 Series E90/92/93 M3 = PCD 5x120, Centre bore 72.5mm and M12x1.5 bolt thread. ET 34-37
5 Series E28 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 18-25
5 Series E34 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 13-20
5 Series E34 M5 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
5 Series E39 = PCD 5x120, centre bore 74.0mm and M12x1.5 bolt thread. ET 15-25
5 Series E39 M5 = PCD 5x120, centre bore 72.5.0mm and M12x1.5 bolt thread. ET 15-25
5 Series E60/61 = PCD 5x120 centre bore 72.5mm and M12x1.5 bolt thread. ET 15-32
5 Series E60 M5 (Saloon) = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-32
5 Series E61 M5 (Touring) = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-32
6 Series E24 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
6 Series E63/64 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 14-20
6 Series E63/64 M6 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-20
7 Series E32 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 19-26
7 Series E38 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 13-25
7 Series E65/66/67/68 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 15-25
8 Series E31 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
X3 E83 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 40-45
X5 E53 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 40-45
X5 E70 = PCD 5x120, centre bore 74.0mm and M14x1.25 bolt thread. ET 37-53
X6 E71 = PCD 5x120, centre bore FRONT 74.0mm, centre bore REAR 72.5mm and M14x1.5 bolt thread.
Z1 E30Z = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread.
Z3 E36 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-40
Z3 M Coupe/M Roadster = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
Z4 E85 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 45-52
Z8 E52 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
Спасибо коллегам с www.bimmerforums.co.uk !
Оригинал здесь: http://www.bimmerforums.co.uk/forum/...e-sizes-t7759/
r4bb1t вне форума   Ответить с цитированием
Старый 17.04.2013, 20:56   #29
Kenny
Аватар для Kenny
Сказал(а) спасибо: 213
Вес репутации: 156
Сообщение от r4bb1t Посмотреть сообщение
Значение вылета без ширины диска бессмысленно при определении влезет или нет, также важную роль играет ширина и профиль резины... приведу пример
5й стиль от Е34 или по другому BBS RC090, имеет параметры 8J ET20 R17 по кругу, по любым каталогам эти диски не встают на стоковые Е36, так и есть если брать стандартную резину т.е. 225/45R17, но в то же время масса любителей тюнинга ставят эти диски без вмешательств в кузов с резиной 205/40R17, по своему опыту скажу что оптимальный размер на е36 это 8J ET35 R17 + 225/45R17 либо 215/45R17...
Да ещё такой момент, что многие производители резины не точно указывают ширину покрышки, где-то написано 225 на деле оказывается 235 и т.п.
E38 730D LBB MetallicA
E30 340 Mr.Henky дрифт корч
Старый 18.04.2013, 00:03   #30
r4bb1t
Аватар для r4bb1t
Тут дело вкуса. И желания.
Мне сзади нравятся 245/45. Хотя сейчас стоят 225/45 по кругу.
На счет style 5:
Диски- BMW Style 5 aka BBS RC090. все 4: 8j, R17, ET20
Резина- 215/40/r17 спереди, 205/45/r17 сзади. Но при такой посадке и резине пришлось "вмешаться" в заднюю часть кузова.
Были бы 205/40 - не надо было бы развальцовывать арки.
Последний раз редактировалось r4bb1t; 18.04.2013 в 00:05.
Текущее время: 03:30. Часовой пояс GMT +3.
